DEI Introduces Heat Reflective Fuel Injector and Sensor Covers Prevents Vapor Lock and Heat...
Avon Lake, Ohio (February 8, 2016)… Excessive heat can cause performance and factory fuel injectors and sensors to be at risk of vapor lock or heat soak which can cause rough idling, slow starting or other potential serious engine problems. Also, cooler injectors perform more efficiently with a more consistent throttle response.
DEI has now introduced heat reflective Fuel Injector and Sensor Covers that are available in packs of two, four, six or eight, that efficiently reflects direct and radiant heat away from injectors and sensors. Constructed of high-temperature rated glass fiber material bonded to a heat reflective aluminized material, DEI’s Fuel Injector and Sensor Covers work well on most any engine configuration with stock or aftermarket injectors and sensors.
The heat reflective covers are made with a split design allowing each to wrap around the individual injector/sensor and then secured with a sewn-in hook and loop fastening edge. There is no need to remove the injector.
  • Part# 010380 – 2 pack
  • Part# 010381 – 4 pack
  • Part# 010382 – 6 pack
  • Part# 010383 – 8 pack
For more information about DEI’s Made in the USA Fuel Injector and Sensor Covers or other thermal protective products, visit www.DesignEngineering.com?utm_source=rss&utm_medium=rss, call DEI at 800-264-9472 or e-mail: Sales@DesignEngineering.com. To keep up with the latest new thermal performance products from Design Engineering, Inc. (DEI), like us on Facebook, or follow us on Twitter.
About Design Engineering, Inc. (DEI)
Formed in 1995, Design Engineering Inc. (DEI) is a major U.S. manufacturer and supplier of high performance automotive aftermarket products selling worldwide to a large number of commercial markets – automotive and racing, V-Twin, Sportbike/Metric, ATV/UTV/Off-road, 12 Volt/Car Audio, Industrial, Marine, and Aeronautical. DEI, located in Avon Lake, OH, specializes in the development of thermal and acoustic performance products as well as cryogenic intake systems and related accessories under the CryO2™ brand, nitrous oxide systems and accessories under the Ny-Trex™ brand, acoustical insulation and sound deadening products under the popular Boom Mat™ brand, as well as a full line of performance coolant additives under the brand Radiator Relief™.
The post DEI Introduces Heat Reflective Fuel Injector and Sensor Covers Prevents Vapor Lock and Heat Soak appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
  1. DEI Introduces Fuel Injector Reflective Heat Covers – Designed to Prevent Vapor Lock and Heat Soak
  2. DEI Introduces Jeep® Fuel Rail & Injector Cover Kit
  3. Royal Purple’s Max-Atomizer: Spring Cleaning for Fuel Injectors and Fuel System Components
Continue reading...
