SOLD Dallas, TX: 2013 Lexus GX 460 Premium
Year
2013
  1. GX460
Dallas, Texas United States
Mileage
136600
Color
White
Outside Link
https://www.facebook.com/share/1QTxCVudYH/
$22,000
2013 Lexus GX460 Premium
Vin: JTJJM7FX7D5059056
136k miles
Usaa is the lien holder
This GX has been a wonderful over lander and daily driver for me. I have driven it on numerous road trips including to Colorado, Arizona, New Mexico and has run great. I have regularly maintained the vehicle and does not have any mechanical issues. Has a couple dings and scuffs but overall in pretty good condition. I wouldn't hesitate to drive it anywhere.
Starfire pearl exterior with black & saddle tan interior, original sticker shows the following options on top of the Premium package: Navigation/Mark Levinson Audio Package, Intuitive Parking assist, dual screen DVD rear seat entertainment system.
Modifications:
uni-filter "mod" on secondary air pump
Prado 150 rocker panels
Voltage booster pro (for the AGM battery)
Method 703 wheels (Including full size spare) 265/70r17 SL rated Falken Wildpeak AT4W with around ~8k miles on them.
Console Vault
Previous owner regularly maintained the vehicle at Lexus (you can search these in mylexus), I have regularly had the oil changed and has new denso air filters, and done the following:
04/25/2024 - 116,334 Coolant Valley Leak resealed by Lexus
05/24/2024 - 119,929 Brake fluid flush, transmission drain & fill, rear&front differential fluid, power steering flush
05/25/2024 - 119, 949 Transfer case fluid drain/fill
07/11/2024 - 121,064 Spark plugs replaced
08/22/2024 - 122,697 Replaced thermostat and thermostat assembly, door check assembly on driver door, serpentine belt
11/05/2024 - 126,225 Front & rear rotors and pads
12/20/2024 - 128,137 5 new Falken wildpeak at4w SL rated tires 265/70r17 (new TPMS sensors as well)
01/14/2025 - 129,168 Replaced radiator , water pump, radiator hoses
01/25/2025 - Replaced battery with AGM X2 27F Battery
04/28/2025 - 133,444 replaced Rear air springs with Lexus parts
5/28/2025 - 136,500 had alignment re-checked under lifetime alignment with Firestone
Google Images Link: gx460 · Thursday, May 29 ð¸ - https://photos.app.goo.gl/QvDMN8ahpjjnXrLv5
Carfax available here: https://link.carfax.com/u/click?_t=098d8472ba974a18af8e380c9ce03898&_m=4ef7faf39f2b447ab423d7a7857079c9&_e=uL6c_L_awtpXFP15flGGLumJRrv-t5sbqUEzVyK9FFfrRpqmeM1TJRySUUZ5eGQUn-i2m65FKyOMcJV6YrRVmas1hqZd1W46ic8P2n68wxWrGYVPk9moLvctAeOumsFLKgfT-gTmjobtZ62LFqNQ2vfef5KkiafzeHShh8fts5qzqnN6aV777yiVE8qzzhOelaVNxHiVL0lHsCQwJ7Zw90BQ3k6gox_HLEcdxhC2HpVIkeDBlCIJBTClyw8XQuZ6ldG0JJhC8v9gwxf-FTLJV72RYohOynbPyDTqfZA9yyCFY4y97pO2coxUiQioZNsevjJZMd_YD-CXDQgSpd33BzaBbO6hb0s7ovKdVLGNOTN9KdB6JSzK1HdGWCXHHkuna6obB9ioUnRMrjnK6iNwlM03cjID9ZoZ7JQa-3FgTRE=
Hi- Does this have the air suspension? Was it standard or an option for this year and trim level?
Yes, and the rear air springs were replaced with Lexus OEM parts last month as a preventative maintenance item. I believe at least in 2013 rear air suspension is standard on the premium package. I still have the original air springs that were fully functional when they came off if wanted I can include them in the sale.
