x2....is it possible you put the wrong leaves on , the drivers side on the passenger and visa versa ?
x2....
You need to pull your rear springs flip them over(only to inspect to see which leaf pack is taller) and the taller of the 2 go on the drivers side
I think the cruiser lean is the frame but nobody is for sure....it just isYeah, but... Why?
What is there on our trucks that weighs the left rear down like that? Or is it the perches are different distances from the shackles?
WTF, over?
Edit: I miss your old Avatar.
Rick
Seems EVERY 60 series I have ever seen has had "cruiser lean" to the DS.
Are aftermarket spring lifts set up to correct this?
Chicago
Tell SOR to go fawk themselves cause they know cruisers need the correctionThe sor kit shows identical part numbers for both fronts and both rears. So I guess its not set up for correction. I'll call on Monday and find out if I missed something. If its not set up for correction, whats a guy to do?
also they recommended using a longer shackle on the one side- as if I would ever hald ass my 60 in such a fashion.
.... after I installed my springs and found the lean was worse than the stock springs, ....
I called and asked what I could do about the problem- the guy on the phone said that the springs are like that " because the minning roads in Australia are typically slanted and that the lean compensates for that",- .....also they recommended using a longer shackle on the one side- as if I would ever hald ass my 60 in such a fashion.
"X2 on the SOR remark- the part numbers are the same, after I installed my springs and found the lean was worse than the stock springs, I called and asked what I could do about the problem- the guy on the phone said that the springs are like that " because the minning roads in Australia are typically slanted and that the lean compensates for that",- no kidding that's what he told me, I also asked him what he drove , he said he drives a corrola, in all the bussiness i've done with them it's the only problem to date, I see that CCOT advertises their springs to " lift and level" youe cruiser. anyway I've got my $1400. suspension with a lean sutable for any supposed minning road,.....also they recommended using a longer shackle on the one side- as if I would ever hald ass my 60 in such a fashion."
