Cruisers and Co
Supporting Vendor
- Joined
- Mar 30, 2023
- Threads
- 6
- Messages
- 753
- Location
- Westminster, Colorado
- Website
- www.cruisersandcompany.com
- Thread starter
- #201
Easy! Just like keeping the 1FZ and turbo charging it instead of creating an LS kit for the 80... I like my Toyotas Toyota and the A750 fits that billJohnny, what was the thought process on going with the A750 and not using the ZF8, for example? Just curious if this is really a step one of alternatives?
Also comes down to the following:
- The A750 is extremely Robust and should get another 300K+ out of it as long as it is taken care of. This is highly proven when looking at 100 series
- Ease of installation - should be a 2-day job
- No floor, transfer case, crossmember or driveshaft mods required
- Minimal wiring - ALMOST Plug and Play... just a few wires need cut and spliced. Where those splices happen is really easy to get to.
- The gearing is great (hi & low) - if you've ever driven an early vs late 100 you know how much of an improvement the a750 was over the 343.
- Computers - the Compushift is extremely robust, proven and the backing/support for it is incredible - won't find the same level of support with many of the other TCUs out there and will likely be on your own for tuning any other unit. This will come pre calibrated for the 1FZ stock computer and we will develop a tune to pair with aftermarket ecu's
- Interior stays stock, no need for a new shifter
- Can get reman units from Toyota
- Support from WAT - they know these units inside and out
- Torque convertor lock up in any gear automatically or manually
