Possible, we're going to find out and go back for blood on ThursdayFuel pump voltage?…
I bet she'll make more, the boosted 3.4 in my Tacoma is closing in on this figure already.my goal is 420-ish / 550-ish. <--- for this truck, but there is another.
I was tired of my Magnaflow on the highway as well and added a Vibrant SS resonator. 3 x 45* SS pipes cut up and welded with the resonator tacked in. The sound is much more tame than straight muffler.I ran a magnaflow 11229 muffler and a real little cat on mine - all 3" stainless - and it's just a tad too loud on the highway. Gonna add a resonator to the back as soon as time allows. For reference, 20 year old me would say it sounds badass, like my Supra, and leave it. 45 year old me wants it quieter on the long trips.
I got old and it sucks.
Also took my 80 back to the dyno and tossed it on after Jim's 55 for a quick pull.
For Reference when we started this journey my 80 made 138 Hp and 191 ftlbs on a stock engine that was rebuilt by Robbie w/ 1mm over pistons. After Stage 1 turbo @ it jumped to 210 Hp and 290 ftlbs.
Recently we have completed the following work on my 80:
So, we did a pull in 3rd gear with the torque converter locked and while it took a while to go from 1000 to 5000 because you are never starting at 1000 rpm the result was astonishing.... 292 Hp and 416 ftlbs w/ boost peaking at 8.4 psi. Hard to believe that bump in power but having driven the truck pre and post it is certainly putting power to the ground much more efficiently with the new transmission. It floats down the road and is much less of a "tractor"
- 3" Stainless Exhaust
- Installed our FMIC
- Completed the A750F Transmission swap
Stock timing 3 BTDCThat sound is not a knock as in pre ignition. What is your timing set at?
This is a stage one. So factory ECUWas it tuned when dyno'ed?
You installed the kit yourself?This is a stage one. So factory ECU
I did yeahYou installed the kit yourself?
No. Cannot feel it. I’m going to hook up my chassis ears tomorrow and try to pinpoint where it’s coming from. I will inspect fan shroud and anything else that moves under the hood as wellSounds like the engine torqueing over and fan blade hitting the shroud or a loose wire or something.
Possibly a valve train issue.
It is not a lower end issue.
A bottom end issue at high rpm is very rapid.
Pinging sounds nothing like that.
Can you feel it when it happens?
