- Joined
- Dec 12, 2006
- Threads
- 79
- Messages
- 3,628
This hydroboost kit designed for the 80 series would probably clear that stuff just fine-
Ibooster… IJS. Locks the 37s at will, and I still have brakes with the engine stalled (or off).
I’m .. familiar. I have one on the F-350, and put one on my 40 back in 2004.I'm familiar with them. My Tesla has one. I prefer hydroboost with an OEM master for correct bias and a clean appearance.
Hydroboost is designed with a nitrogen pressure accumulator to deliver maximum braking pressure with the engine off for 1-2 pedal cycles.
This is better.
That’s classifiedWhat master cylinder did you use?
Back in 2004, the GM pattern master that matched the hydroboost. But that truck has wilwood front and GM pattern rear calipers and rotors. It was 2004 and it was the best solution at the time. It stopped nicely on 35s. Didn’t have to play with bias at all. Never even installed the p-valve. (If they’re setup right, you don’t need one.)What master cylinder did you use?
I'm (impatiently) waiting for mine!
The R&D isn’t done yet and you’re better off waiting for it to be done.I'm (impatiently) waiting for mine!
I think I'm part of the R&D...but I'll let Johnny confirm lolThe R&D isn’t done yet and you’re better off waiting for it to be done
Your updated bracket should be out for delivery today.I'm (impatiently) waiting for mine!
@reklund5 is part of the R&DThe R&D isn’t done yet and you’re better off waiting for it to be done.
Place them!is this when we place our bets?
400HP/450TQPlace them
Will this be all-wheel or 2-wheel on the dyno?400HP/450TQ![]()
Im pretty sure this one will be tested in 2WD @Cruisers and Co ?Will this be all-wheel or 2-wheel on the dyno?
YesIm pretty sure this one will be tested in 2WD @Cruisers and Co ?
Bummer, but that's how the game goes! Just another bump in the road to an awesome and well sorted productSo unfortunately we ran into a hiccup and the piggy is going back to the barn for now but will be back! We got into it and started loosing fuel pressure at the higher end of the pulls so we need to figure out why we’re losing pressure and then bring it back for a second round.
What we did make was still great #’s but overall a disappointing morning and I am not happy with the overall result.
For now at the wheels it is making 370 hp and 507 lb-ft. 400/550 is well in range when we get this sorted
400HP/450TQ![]()
