Crankshaft Angle Sensor wiring - help needed
Columbia, SC
Hey all - in the process of putting the engine back together from a water pump / timing belt / fan bracket replacement I messed up and pulled the wires out of the plug going into the crankshaft angle sensor. I was able to determine the connector is just a standard F-type 2 wire connector and ordered one with pigtail wires installed. My question is does the polarity of the wires matter? I can't find any pictures or wiring diagrams showing which color wire goes on which side. After peeling back the tape and protective cover their is a green and gray wire. Any help or pictures showing which color goes where would be most helpful.
