Crank Bolt
Breakdown and buy a 3/4" impact gun and air compressor. It makes dealing with this and tough suspension bolts a snap. It's unreal how well an impact gun works.
I have an air compressor but a cheap husky impact gun, the husky really does not have much power and I should probably get another. My air compressor is a larger nice one. I will go get an impact if that would take it off but not sure at this point? Any advice on what impact to get? I need one anyhow. How many psi does the compressor need to go up to in order to put out enough psi to rip this thing off?
Putting that much torque on opposite ends of the crank makes me nervous, personally. That said, apparently the trick to keep the bolt from slipping off the torque converter/flex plate bolt head is to use a 14mm deep impact socket. I got one for very cheap on amazon along with my 24" 3/4" breaker bar.
The official toyota tool bolts to the front of the harmonic balancer hub with the bolts you had break off. Thing is, when the bolts are tight against the plate steel of the tool, they are creating clamping force and friction between the tool and the harmonic hub. This allows MUCH more force than what is needed to shear the bolts themselves.
I'd start looking at fabricating a tool to hold back on the harmonic balancer. TDI VWs require a LOT of torque (stretch bolts) on their crank bolt with a much smaller bolt circle than on the 1FZ. \the tools you buy for this are small with NPT threads to run whatever length piece of iron pipe in as a handle. Works great.
ok, so it sounds like I really need a 2nd hand here to hold the 14mm socket in place? that seems to be the problem as once I get some torque on the pipe the socket pops loose. The only other thing I can gather is to somehow shim it in place. Maybe I can get a neighbor to help.
yeah I am using a 14mm deep impact socket. I am going to try and have a neighbor hold that 14mm in place. I think that has got to be the key. I think the socket is just walking off of the bolt when I apply torque. I tried to apply it smoothly to the bar and not jerk it but it still pops off. I am thinking it is going to take 2 people.
also, I heated the heck out of the bolt with map gas as well.
and a pic of the carnage, uggghhhhh
the oil pump cover screws better come easy or I am going to lose it.....
Guppie- here's what I had to do, as I recently had this problem too.
1. Bump start method, alternating with...
2. Blow torch, alternating with...
3. Hammer wrench
We pounded the s*** out of that bolt for hours and hours and eventually it bump started off. But I'm not kidding- hours and hours of work to do it. We took turns with the hammer wrench. Couldn't feel my hands that night, and they were tingly the next day. Destroyed Lord knows how many sockets, breaker bars, wrenches, etc in the process.
But once it came loose you could turn it with your hand. And the threads were clean and new-looking. Weird as hell.
I borrowed a 3/4 breaker bar from a friend. It was a northern tool brand bar.
I broke several other smaller bars and the one from HF. Impact wrench didn't do anything either.
Starter method finally broke it loose after 3 punches.
Oil cover plate screws however... I wound up drilling them out. The top ones just would not cooperate.
I wound up putting a new cover when I swapped the engine.
Good luck!
I feel your pain, I have been working on my BMW 540 crank bolt with about the same amount of progress.
If it's not going to go, don't beat it more than a couple of times. In the couple of times that I have seen them not go, it turned out that some genius bathed it in loc-tite. These bolts have a bunch of thread area, so loc-tite has a big effect, luckily loc-tite gives up at ~300F. It doesn't take a bunch of heat, but the heat needs to get to the thread area, needs time to soak in.
If you need to put big force on the bolt, my first choice is impact, starter method or 3/4" impact, a good one with proper air supply. Attempting to hold other parts of the motor is likely to cause damage, leading to more repairs.
I had one that no matter what I did it would not come loose. The bolt has a huge flange area on it and it puts a lot of spring pressure on the balancer. So I took a dremel with a cut off wheel and cut a few slits in the flange of the bolt. Once the spring tension was off the bolt face, it came off easily. The price of a new bolt saves a lot of time and frustration.
Edit. Don't mar or cut into the balancer. That is why I used a dremel, for control. Once your almost through, put a cold chisel in the groove to break the last little bit.
Can you get the 2 bolts out of the pulley? I have a crank pulley holding tool I welded up a while ago you can use. Unfortunately I won't be in town until Sunday.
Also have a socket and 3/4" breaker bar.
thx Brett, I could probably get them out, that is going to be the next step if the socket thing does not work. My concern is that I round off that bolt head, then what?
I'm not following you, any pics??
got mine off using the 14mm deep socket method....had someone hold it in place while I started to turn crank bolt. Held good
Think I needed a piece of pipe on a breaker bar for leverage but came right off
And if you think this is bad wait till you strip one of the oil pump cover bolts lol
those were way harder to deal with
You have something else going on.
Do not make deviations from this plan.
Go get the 3/4" Breaker Bar and Socket from Harbor Freight (No Torque Wrenches). You can return in later for all your $ back and tell them it didn't work.
Heat that bolt smack dab in the middle using propane or MAP or Polyethylene Gas, till it is hot or the rubber starts degrading. Hopefully it will wick the heat to the threads, but more likely bolt will wick heat into the Rubber of the Balancer. Do not ruin the Balancer!
Have a bungee hanging on Passenger Frame Rail. Hook up bar and tap starter.
If it does not come loose I would try 3X.
No Success: Take 3/4 wrench and go to Home Center Store and get a pipe that fits over handle. Buy about 4' and slip 12inches or more over handle of 3/4 Bar.
Get a 14MM impact socket and put it on the Fly Wheel inside inspection cover.
Use your bar and pipe and heat and loosen.
If that does not work: Look in your HF socket kit and get the next size up socket.
Go to Fastenal and get that size nut, 32mm?, 35mm?, 37mm?
Have a muffler shop weld the entire center of that nut to the existing rounded off bolt.
Attempt to remove again.
If none of this works....
Sell that rig for parts and get a Reliable Range Rover
