pull the plugs, put a battery charger on the battery, rotate the breaker bar so it is pointing south so the engine gets to turn 90* before the bar hits the frame and then let her rip!
yeah the starter method is just not working, like I said I lashed it tight to the frame rail. ...
I've got am 18" 3/4 HF Breaker Bar in North County if you need to borrow it.
You don't put it against the frame rail. We start with it hanging vertically, the motor momentum, then impact with the frame will knock the bolt loose or break the tool. Have done it tons of times and never needed anything over 1/2" dr.
The problem with using a torque wrench (other than destroying the mechanism) is that it has some 'give' at the torque 'click' point and that will absorb some of that 'hit' you are trying to achieve with the starter bump method.
cheers,
george.
I really hope you won't take this the wrong way.
Are you sure you are not tightening the bolt?
Its round to the left... it's correct.I really hope you won't take this the wrong way.
@1973Guppie you are scaring me... I will have to do this also very soon, oil pump is leaking. I'm really dreading this job.here is a pic of the bolt, ordered a new one from toyota, just gotta get this one off before it gets too rounded!
It's a right hand thread, so CCW to remove - which is what the starter bump will do.
Certainly worth heating the bastard up at this point - if the PO used Red Loctite or was a direct descendant of Samson then heat may be a good/only option. Of course you may also fry the harmonic balancer rubber and I'm guessing you'll be changing the oil seal too...
On several 80's I've had to remove the crank bolt (5 or so when doing S/C installs), they all broke free on the first or second go or broke the breaker bar. But these were all relatively new and so the crank bolt was definitely only ever touched by Mr T during original engine build.
cheers,
george.
