Crank Bolt
got a new 1k lb torque air gun today with 1/2 hose. After talking with a few friends, not comfortable with the socket method and twisting the crankshaft up. Going to tear apart the front end tonight and hopefully it will break free with the air gun.
yeah I got one with 1000 lbs of torque, it was $89, they had the big earthquake 3/4 impact but it was $250 which I could not justify. I guess if the 1k does not do it I can go back and get the earthquake one. Is the "earthquake" thing that effective or just marketing?
I have a 3/8" earthquake impacting air ratchet and I use it all the time. It kicks a$$. It's way better than the 3/8" craftsman which couldn't break even small bolts. I usually don't have good things to say about HF tools, but my Earthquake impacting air ratchet is really nice. If I was going to buy a 1/2 inch impact gun I would give the earthquake a shot. With a 20% off coupon and a good return policy I don't see how you can go wrong.
All that being said, my brother has the regular 3/4 harbor freight impact gun and it broke the crank bolt just fine. Only downside is that it's huge compared to a 1/2" impact.
I cant imagine how painful this is. And here i thought the PHH was frustrating[emoji22]
Sent from my iPad
1000 pound torque air gun and it still not coming off! Suggestions? Fxxx me. I am hearing the bolt w map gas for 30 min then will try again. I let the torque gun wail for about 30 seconds and did not budge
My setup
30 min of map gas, noticed the pulley was moving a bit. Put the pulley holder on w bolts. Still no go. What to do? I am at a loss. Should I go try the 1400 pound earthquake gun? Weld on the tip of the bolt to heat it up?
Torque Multiplier would solve the problem pretty quick! Plus allow you to actually retorque the bolt back on with ease.
That 3/4 HD gun I ran off of 3/8 unknown if it affected anything...diesel and heavy equipment shops probably have a 1" drive mega impact, maybe trade some beer for a borrow? I did some double checking and the rental I was looking at wasn't that beefy after all (electric with 350 ft lbs)
You'd need at least 90psi at the gun (check its specs for ft-lbs at what flowrate/pressure) and as large a diameter hose with as short a length as possible to actually get close to the rated ft-lbs of the gun.
You have another issue going on.
If your hitting a true 1000 ft/lbs toque you should have sheared the head off the bolt at nearly 3X the specified Toque.
I would have AAA flatbed it to a trucker stop and use the 1" impact gun, but what are you going to do when the bolt is broken off? At that point you have to remove the crank.
We have a 1" Impact here at work, but CA is a long ways from OH.
I have no idea what the CFM Requirement is for a 1" Impact.
A torque multiplier is basically a transfercase for your breaker bar. You put your wrench in the back and apply 200ft/lbs and the output is say 400ft/lbs, etc.
please explain further, I don't understand what you mean by a "torque multiplier"?.....
Whoah! Dude, TAKE YOUR TIME, relax, and focus on using heat and hammer wrenching at a rational setting- I used 300 ftlb of torque, with the occasional bump start. It does work, you just have to have patience! Don't sheer your bolt!
