Crank Bolt
this truck does not like me, idler pulley in front of oil pump cover was seized in place. Had to drill it out. FYI, if yours is seized you can drill it out easy, step up on the drills and then the whole thing just falls apart.
good news is the oil cover screws zipped right out! man that milwaukee is worth it's weight in gold.
Great news about the bolt. That was quite a drama !!!!!! The 'milwaukee' you reference, can you pls share cato/part # ?
Thanks !!!!
Grats!!!
Finally got it.
Dang, I hope mine is not this bad.
I broke off 1st oil pump screw then used easy out. Remaining screws got Pencil torch and PB Blaster, then impact (Bosch).
They were cake, just like my Crank Bolt. Your experience may vary.
Job was much easier than replacing a tie rod end.
That required Acetylene and a 23x1.5mm tap
So I'm going through similar drama to Guppie with the white cruiser. Started doing baselining and have gotten to the crank removal and no joy after ~12 times with the starter bump and 3/4" breaker bar on a 30mm socket. Couple of questions ...
Can the AC condensor be moved out of the way forward maybe 2", then I can at least get my Kobalt 1/2" impact on it (650ft/lbs). Do you think that is enough to break it loose? I have access to a Milwaukee impact with closer to 1000ft/lbs if needed.
Do I need actelene to heat the bolt, or will propane work?
Would be willing to purchase an air powered impact good to 1000fl/lbs, but would need to run it off my PowerTank setup and need to see the overall length to know if it will fit on the bolt or not. Anyone have or using this:
https://www.lowes.com/pd/Kobalt-0-5-in-1000-ft-Air-Impact-Wrench/1000404871
only way to know "if it will work" is to try. I have done many of these and it seems some come loose with the starter bump method and many others are much harder. I don't know why. Maybe the environment they lived in, maybe random luck. Map Gas from home depot is very hot so use that, yellow bottle. I finally was able to get the crank on this car using ALOT of map gas heat and a 1k plus air gun directly plumbed to the compressor.
Noah
@1973Guppie How long did you heat the bolt before trying removal? Thanks for the tip on the Map Gas. I will pick that up for sure.
can't remember, I know that at one point I heated it up for 30 min straight, the 1k gun with straight air pipe to it as well as walking the bolt forward then reverse seemed to break it loose finally, I also would hit it with some pb blaster alot between heat cycles.
3/4 Harbor Freight breaker strapped to underside of PS frame with 30mm 6pt.
This worked like a charm for me.
