This is crazy, there should be no way that bolt is staying on there. Even if you didn't secure the pulley the compression alone should keep the crank from keeping up with that impact gun. The only thing I can think is a set screw, but I don't know how the F you would or why. Just to check it off your list you might lay under the truck, look up at where the belts go between the valleys on the pulley, then rotate it around and see if you see anything weird.
