Crank Bolt
"the whale's vagina", CA
So, I am working on this 97 fzj80, trying to get the crank bolt off and nothing is working. I tried the starter method multiple times and it will not break loose. I am starting to round off the nut using the starter method which makes me nervous.
I have already broken a 1/2 inch breaker bar and have now been using a 3/4 torque wrench under the drivers side frame rail using the starter method and no go. Has anyone had to use heat to get that bolt off? I am lashing it as tight as possible but after about 10 starter bumps it falls off. I am thinking of putting some map gas onto that bolt and then going to get a 1/2 torque wrench with some longer pipe and just hang on the thing?
any suggestions? this is scaring me if I can't get this godamn bolt off. I did this on my 80 and it was not this hard whatsoever.
Someone correct me if I'm wrong, but you should be able to take the inspection plate on the transmission and secure the flywheel from moving (I don't remember exactly how) but be careful not to damage it, then use a breaker bar and a lot of muscle to break loose.
Other than that you can make tool to like this one to connect to the crank pulley.
Sent from my iPhone
<snip> and have now been using a 3/4 torque wrench under the drivers side frame rail using the starter
That is a great way to wreck a torque wrench.
Also a 3/4 inch breaker bar should be against the bottom of the passenger side (RH) frame rail.
You are saying you're using a 3/4" TORQUE wrench as a breaker bar??
I'd suggest you get an actual 3/4" breaker bar. You are using a 6 point socket on the breaker? I'd suggest an impact socket since it is designed to handle shock loads.
A little bit of play versus tied tight against the frame will also give you a bit of 'impact'. And it should be tied to the PASSENGER side...
cheers,
george.
Never use a torque wrench to loosen, I assume you have a breaker bar on the correct side of the frame? I use a air impact work and it always blast it right off, I think I used a four foot bar chained to the frame took two bumps
Pinhead, do you mean hit the starter harder? The engine just locks up. I am guessing I should just keep bumping it? Any chance of screwing something up? Do u think I should try some map has on the bolt?
What I mean is let the engine do the work for you. Put the handle of the wrench closest to the floor and not the passener frame rail and let the starter do the work.
I didn't have luck with the bump method, and my battery ended up dying. I ended up trying the socket in the torque convertor version and it worked like a champ. I had a short 3/4" breaker bar too so I put a 4 foot long pipe over the handle to give a bigger lever arm. Mucho torque with this setup, crank bolt didn't have a chance. I highly recommend this method.
yeah the starter method is just not working, like I said I lashed it tight to the frame rail. I am going to try it one more time per pinheads method of putting the pipe against the floor. Can you provide more info on the socket in the torque converter? I have used a long pry bar before in the flywheel to keep the engine from rotating.
Remove the bell housing inspection cover plate and you can see the torque convertor fly wheel plate and bolt heads that hold the plates together. You want to put a deep socket on one of those bolt heads and turn the crank bolt until that socket rotates around and hits on the side of the bell housing inspection hole. Once the socket engages the side of the inspection hole, that holds everything from turning anymore, then you should be able to break the crank bolt free with your 3/4" breaker bar and cheater pipe.
Are you saying this in order to have some momentum and an impact on the frame?
ahhh, gotcha, I thought you meant to have the breaker bar lodged against the ground instead of the frame rail. So you are saying that the momentum of it swinging up and against the frame rail should help snap it loose? will give that a try, thx for bailing me out again pinhead! :) I am guessing this will work based on your past advice. You da man.
