Crank Bolt
I have pulled almost a dozen of these off. All using the $80 Harbor Freight Earthquake impact wrench.
Quick, easy, effective, and you can stop this thread!!!
Do you know which way the flywheel spins? I thought it was CW if you are facing the FW, cant remember. But, if you put that deep socket on that bolt head and its on the "wrong" side it just falls off. It has to be on the Tq side of rotation(same direction) from the beginning- and tensioned on the housing flange or it WILL fall off. This was something I encountered. Good luck and this thread will END!!!:popcorn::wrench::zilla::bang:
Crank nut removal
Here's how I removed one on a 2F. The rope on pulley trick might give you another option for holding the pulley/crank stationary while you attack the nut.
Crank nut removal
Or possibly damage/destroy the harmonic balancer rubber...
cheers,
george.
I am not following you. I popped off the little plastic view cap and put a socket on the only flywheel bolt I can see. The flywheel rotates towards the drivers side. The only place I can get it to bind up at all is on the window towards the drivers side. I don't see anywhere else it could bind up?
yes, just wondering if I can get an impact gun in there? I have the rad removed but don't want to remove the whole front end and decompress the ac, etc.
got mine off using the 14mm deep socket method....had someone hold it in place while I started to turn crank bolt. Held good
Think I needed a piece of pipe on a breaker bar for leverage but came right off
And if you think this is bad wait till you strip one of the oil pump cover bolts lol
those were way harder to deal with
yeah I have done the oil pump cover bolts, know the struggle well, just have never had a crank bolt like this one. I have pulled lots of cranks over the years and nothing like this.
Sounds like you got dealt a bad hand.
What is a "universal crank bolt puller"?
If you round off the bolt, just weld a large nut on it and try again. The heat will help.
thank you for the nut idea, did not think of that, makes me feel better there is a 2nd option. I am also thinking of welding a circle on the front side of the bolt to heat the heck out of it. What do you think? I am guessing I can weld a circle on the front and heat it up nicely and then grind it back down. I am getting a new bolt anyhow. I am going to go get a new impact today too along with some new larger hose.
You have something else going on.
Do not make deviations from this plan.
Go get the 3/4" Breaker Bar and Socket from Harbor Freight (No Torque Wrenches). You can return in later for all your $ back and tell them it didn't work.
Heat that bolt smack dab in the middle using propane or MAP or Polyethylene Gas, till it is hot or the rubber starts degrading. Hopefully it will wick the heat to the threads, but more likely bolt will wick heat into the Rubber of the Balancer. Do not ruin the Balancer!
Have a bungee hanging on Passenger Frame Rail. Hook up bar and tap starter.
If it does not come loose I would try 3X.
No Success: Take 3/4 wrench and go to Home Center Store and get a pipe that fits over handle. Buy about 4' and slip 12inches or more over handle of 3/4 Bar.
Get a 14MM impact socket and put it on the Fly Wheel inside inspection cover.
Use your bar and pipe and heat and loosen.
If that does not work: Look in your HF socket kit and get the next size up socket.
Go to Fastenal and get that size nut, 32mm?, 35mm?, 37mm?
Have a muffler shop weld the entire center of that nut to the existing rounded off bolt.
Attempt to remove again.
If none of this works....
Sell that rig for parts and get a Reliable Range Rover
thx but most of that I have tried already.......
......I have pulled lots of cranks over the years and nothing like this.
Somehwere Beavis and Butthead are luaghing !
In all seriousness though, are you using a 6 point socket and 3/4'' bar now ? I read back through page one and saw the stuff on 1/2'' drive. The only time i've ever used 3/4'' stuff was on these crank bolts and it makes a huge difference. I just lock the flywheel with a 14mm impact socket, rotate the crank pulley until it locks, then get on it with 3/4 breaker bar and a 3' section of pipe. They have all come off with no problem. If you have already tried this then please forgive the repeat.
I pulled the radiator, and everything else that was obstructing the view of the crank pulley nut. And I pounded the crap out of it on the hammer wrench + blow torch. It works, you just need to play loud heavy metal music and beg the neighbors not to call the cops because of all the cussing.
I am thinking I can gain some room in there by pulling stuff off and out of the way. I am guessing the ac stuff can be left connected and pulled to the side?
yesssssss sir, 5 foot of pipe.....
thinking of doing this so I can get a straight shot at it. Yeah the neighbors know I am the crazy guy in the neighborhood. Old school rap on pandora and lots of swearing.
when you pulled all the stuff out from the front did you have to discharge the AC? or could you just pull it out of the way?
I have a 1/2 inch Ingersoll rand impact gun that I've used with great success. My brother has a 3/4 inch harbor freight impact gun which is half the price of my IR impact (regular not earthquake, earthquake wasnt out yet when this one was purchased) which we have dubbed "big bertha" that has worked for a land cruiser, a sequoia, and a 4 runner crank bolt. Typically I use about 95-100 psi, to compensate for the drop through the 50' of hose. My compressor has a 27 gallon tank and is rated 5.8 scfm at 90 psi.
Weellllll... here's confession time.
I accidentally yanked on the AC line and blew highlighter fluid all over my face. My wife said I looked like Bart Simpson. :(
It's a dick move but I bought a 3/4" husky at HD, zinged off the crank bolt with authority, and returned the impact an hour later. IIRC there was a local tool rental that had one that wasn't in stock, so maybe check for a tool rental if you don't want to do the return thing.
Husky 3/4 impact= 1400 ft lbs.
