Build Chronicles of Bonnie and Clyde
New BIO Bumper ordered and paid for. Now to take cutting wheel to Clyde's highly modified current bumper set up.
Eastwood Internal frame coater plus, ordered, next week hope to get that done then remove axles and prepare frame to haul to Tulsa.
Amazed how nice everything coming apart. No seized bolts as of yet. Hard to believe for as old as it is.
Went to HF and purchased small and cheap US cleaner to see how well it would work cleaning up the bolts and any small brackets I am removing.
After my last Colorado trip I did have quite a bit of dirt road stick to the fluid film on the bottom of my bed but it mostly came off easily. I could see the hesitation, I don’t have a choice here in the midwest though. Every fall it’s a ritual.
Yeah the reapplying annually doesn't do much for me. Since fluid film stays wet to a degree I have images of my frame looking the same color of the dirt roads we drive down everyday to get home.
Looking for the one and done option!
That sounds like great fun the next time you crawl under to do an oil change or drop the skid plate!
Dust held on by oily, sheep-flavored product...
Cutting up the crude fabrication for bumper and tire release.
The Diablo blade always makes easy work of it.
Off like a herd of turtles here.
After further inspection sleeve welded to the frame from inside.
Going to use multitool and don’t have any metal blades. Go figure, plenty to work on.
And they just kept welding!!
Any ideas how to best cut the welds tucked on top/bottom? Multitool won’t reach (by 3-4mm). Gonna break out dremel but curious if anything out there I can use to cut in tight space?
Was that bumper bolted to the frame or was it just welded on?
I would blow out the welds sideways using an acetylene torch. The gas flow moves the welds as slag.
B
Bumper bolted on but hitch sleeve was welded to the frame. If I can knock out the welds on top and bottom which are crap at best I should be able to remove it.
