this time my Echo CS341 arborist saw. Love that little thing. So handy.
Started out a few days ago, I was doing light trimming and when I was using the saw overhead it was sometimes stumbling. First hint?
Yesterday, I was cutting some pine. No obvious overhead issue noticed this time. At first it was OK then it gave me progressively more trouble. When I was revving it out of the wood it sounded fine and was going fast. But then when cutting it would slow down dramatically and feel like it wasn't cutting, no power and little wood chips. If I took it out it ran fast again. To finish the cut (8" across) I had to remove it from the wood, rev it up, and put it back in. Maybe took 5 or 6 times. Felt like lack of fuel or bad carb setting. But then I noticed something odd, the chain was showing a bit of smoke -or maybe it was the guide bar, not sure. Only wisps but not done that before. Seems like something was overheating. At that point, I stopped to figure it out. Had run a file through the chain just before and only cut for about 1/2 hour, just soft fresh pine, and feels sharp still so not a sharpness issue I think. Oil level has decreased -I think- as expected so should have been lube.
First guess is dirt in the fuel system, maybe dirty air filter. Puzzled by smoke.
Suggestions as to likely causes before I look seriously into this?
