SOLD Central Florida, 2006 Lexus GX470 Asking $17,000k
Status
Not open for further replies.
Year
2006
  1. GX470
Florida United States
Mileage
173500
Color
Blue
Outside Link
https://www.cargurus.com/Cars/inventorylisting/viewDetailsFilterViewInventoryListing.action?#listing=329073093
2006 Lexus GX470 (Non-nav)
4.7L V8 32V
Gasoline
All Wheel Drive
3 rows, rear AC
VIN: JTJBT20XX60116210
No accidents or damage reported to CARFAX
For sale is my beloved 2006 GX470, V8 full time 4x4, Rust free 3 owner Florida suv. Non-navigation with 6 disc CD player and cassette tape. Driven daily over the past 4 years and driven approx 45,000 miles with no major issues. With having 4 kids now, we have outgrown this vehicle to be comfy. Vehicle was serviced by Lexus for the first 100k miles. AC blows strong and cold, both front and rear. Heated driver and passenger seats.
This vehicle has been with me all the way up to the Canadian border, the Upper Peninsula in Michigan on snowy covered roads, and multiple Midwest road trips that never left me stranded and kept us safe. If you’re looking for a good girl with an easy past, this is the one.
Routine maintenance and upgrades includes: fluid/filter changes, cv axle replacements, outer tie rods, rotors, calipers, SS brake lines, sway bar end links and bushings, Toyota reman steering rack and new power steering reservoir, Toyota reman Starter, NGK Laser Platinum spark plugs, K&N oil filter, new radiator
Ironman 4x4 America 2” constant load nitro gas front struts, 2” rear constant load heavy duty springs with adjustable load leveling perch,
Ironman snorkel
Ironman classic off-road GX470/Prado bumper
Badlands 12,000lb steel rope winch, with wireless and wired remotes.
1” body lift
New Toytec side engine bay covers
Led head lights
Led interior, exterior and running board lights
Diehard battery
All new 6 window felt belts replaced
Reese Class 3/4 hitch
Cost of upgrades not including install:
New Ironman snorkel $300
New Ironman lift and airbag delete adjustable perch $1,438
New Ironman winch bumper $1,299
New Badlands 12k steel rope winch $579
New 20k lb snatch block $30
New Snatch strap $28
60” Hi-lift jack $108
New power stop Cross Drilled and slotted rotors, ceramic pads, powder coated red calipers $431
New Steel braided brake lines $100
New CVJ Toyota reman steering rack $732
New Power steering reservoir $69
K&N filter $55
Rear Ext sway bar links $18
Total $5,187
Maintenance log:
Aug 2018
New Timing belt @ (137,322 miles)
New Water pump
New Idler pulley
New Tensioner
New Thermostat and seal
New serpentine belt
New serpentine idler pulley
New valve cover gaskets
New spark plugs
New spark plug tube seals
New pcv valve
New windshield (aug 2018)
Fixed clogged condensation AC line 8/28/18
New pass wheel bearing and hub (sept 2018)
New PASS side axle (sept 2018)
New pass outer tie rod (sept 2018)
New front rotors and pads (sept 2018)
K&n cleanable filter
New cabin filter
Liqui moly 5w30 full synthetic (137,300 miles)
5x BFG 265_70_17 ALL TERRAIN KO2 @ 132,000
Transfer case seal replaced and refill. 9/29/19
New battery 12/10/19
New radiator 1/28/2020
New drivers side axle 2/14/20
Topped off front diff fluid 2/14/20
5w30 Liqui Moly syn 2/15/20 (147,600 miles)
Mobil 1 extended performance oil filt 2/15/20
New oil drain plug crush washer 2/15/20
New drivers side tie rod 2/19/20
New Front diff oil seals both sides 2/19/20
New sway bar bushings 2/19/20
New front sway bar links 2/19/20
Tire rotation 2/19/20
Alignment 2/20/20
3 wiper blades 2/25/20
6-window felt belts 2/26/20
New denso TOYOTA reman starter 2/27/20
New coolant crossover gaskets 2/27/20
New water cross over o-ring 2/27/20
New knock sensors 2/27/20
New lower intake manifold gasket 2/27/20
Throttle body cleaned 2/27/20
5w30 Liqui Moly syn 9/8/20 (152,848 miles)
Purolator Boss oil filter 9/8/20
Tire alignment 156,000 12/1/2020
New Powerstop front & rear calipers, pads/rotors 12/12/20
Steel braided brake lines 12/12/20
LED headlamp hi/low and fog lights 12/12/20
LED running board and lic plate lights 12/7/20
New TOYOTA OEM reman rack&pinion steering 1/14/21
New power steering reservoir 1/14/21
New diehard battery 2/12/21
Oil and filter change 2/14/21
1” body lift May 2021
Ironman snorkel June 2021
Airbag delete
Ironman 2” constant load front lift 2.0” rear constant load lift. Struts, springs shocks (6/22/21)
Oil and filter change 162,370 miles (6/24/21)
Oil pan plug gasket (6/24/21)
Cabin filter (6/24/21)
Liquimoly motor oil saver (6/24/21)
Ironman bumper and 12,000lb Badlands winch install September 2021
Oil/filter change full synthetic (167,000 miles)
Oil/filter change full synthetic (173,500 miles) 4/26/22
Items that need work:
Faded clear coat on hood and above windshield and rock chips on hood. Curb rash on wheels. Typical dashboard cracks, front right door speaker needs replacing, small exhaust leak on passenger side that seals once warmed up,driver side leather seat needs replacing or seat cover.
$17,000 OBO
(561) 676-6590
Thomas.vorstman@gmail.com
Status
