CDL in a '94 FZJ
Five miles from Canada
I own a '94 FZJ80, and I noticed in the '94 Brochure posted on toyotareference.com that the CDL was standard. Mine does not have CDL, just the ATC (Transmission) button. Any thoughts?
Are you talking about the center diff lock or the center diff lock switch?
The center diff lock wwill automatically engage when the truck is put in LOW. On the earlier years there was a switch on the dash for that function. You can add the switch as well - look up the Pin 7 mod.
You have a CDL (Center Diff Lock). You do not have a CDL Switch.
You can purchase one from Slee or cdan, or get another switch (the emergency switch works) and relabel it for CDL switch use (don't just unplug your current emergency flasher swich and use it as the CDL switch. That works fine for the trail/emergency, but you lose your turn signals). You have the CDL switch pigtail already setup.
If you get the CDL switch look into the 7 pin mod.
By the way, the FAQ should answer most/all of your questions: https://forum.ih8mud.com/80-series-tech/84888-faq-80-lx450-july-24-2008-added-lspv-modification.html
