CCOT lift kit 60/62
Check the Cruiser Tech forum. There are some folks discussing these springs.
Whoops. Sorry, the discussion is right here in the 60/62 section. You probably saw that...I'll shut up now. :D
dont go with a ccot lift go with an old man emu 3 1/2 lift as far as tires i have 35's and i dont rub hradly ever and 33's will work real well if u ar gunna do a lot a offroading like extreme flexing but if ur not 35's look real nice tucked under there
yea ill post a pic on here pretty soon as soon as i get a digital camera which should be on sunday or sometime in the weekend
My HFS suspension just arrived. I am hoping that I dont have the same problems mentioned in that other post. It will probably be October before I have a chance to install them, but will report back on them after I do.
I got mine a while ago, installed a couple weeks ago. It's alright, I liked it better when it wasn't broke in at first, it was a bit firmer, which I liked. I also used greasable shackles and spring pins, which makes it ride really nice. Of course, I was driving around in a F350 before that for a couple weeks, so it might be a bit rough :P it seems to lean a bit to the left, I think its still settling a bit though, might have to shim the right side down or something. The steering with the HFS on mine, seemed fine, didn't need any shims to correct it. I have a '90 FJ62. hope any of this helps...if you got any questions just ask :P
