This noise just started within the last few days. It’s been intermittent, and sometimes it doesn’t do it at all. I think my wife described best as having one of those toy cars that you put on the ground and roll it backward to load the spring, let it go and it shoots across the floor. If you were to pull that toy car back to load the spring and then lift it off the floor letting the wheels spin out…you get an idea of the noise. The weird thing is that the motor runs as strong as ever. The transmission isn’t slipping, losing power, or popping out of gear. It has made the noise after downshifting from 3rd to 2nd gear, but it’s also done it when up shifting as well. If I push in the clutch, the noise stops.
Any suggestions would be appreciated.
William
PS: The clutch was replaced about one month ago. The rear main as well as the pilot and throw out bearings etc…were supposed to have been changed too while they had it open. I had been using a local shop since they had an old school Toyota tech who had worked on cruisers before. Previous work was fine. When I took her in for the clutch work, they didn’t tell me he was no longer there. I probably would have taken it to the Cruiser guys in Providence instead had I known. I’m not saying they didn’t do the work right since I can’t say whether it’s related or not at this point.
William
