Can an FJ80 Pitman be reamed to GM taper?
BC Canada
I need to make a new drag link.
My FJ80 steer box has an FJ80 pitman arm. Can the hole in the FJ80 pitman be reamed / tapered to fit a larger GM tie rod end? Will there be enough steel around the hole in the pitman if I do this?
Anyone done this?
Thanks.
I've done it and it works fine. You'll need to find or buy the tapered reamer, but then it's a 5 minute job in your drill press.
I run an 80 pittman on my FJ60's steering box, reamed to 1 ton ends. It's been that way for close to 10 years.
Thank you Drew. That helps.
I also have an FJ60 arm.....and as you prolly already know......it has a larger taper hole in it than the FJ80 pitman hole size. Do you know if it too can be reamed to the GM taper? I may need to use it as it's got more drop than the 80 pitman, just won't know till I mock it up.
I'm already buying an fj80 reamer.......looks like I need a GM one too.
Not sure. There is not as much meat in the FJ60 steering arm.
As was mentioned...plenty of meat on an 80 arm for 'murican TRE's. I'm 99% sure I've done a 60 arm as well, years ago--no issues I'm aware of.
This is after tapering to the larger size:
And with an end installed:
Another SAS'ed 100? Do you have a build thread?
Thanks for the help guys. Nice to have you chime in.
I'll go forward with the plan.......and use a gm tie rod end at the pitman arm.
