(CA)32 gal jeepspeed fuel cell
Paradise, Ca
I bought this used jeepspeed cell for my fj40 build. It was originally modified to run a tacoma in tank pump, sending unit and emmissions BS. It now has two blank plates, to be configured however you would like. Rough dimensions are 31.25" wide x 23" deep, sides are 13" sloping to 8". The flange is 3/4" wide and is not included in those dimensions. As can be seen in the pics, the flange was cut and bent to clear some shackle mounts, but is still in tact and now bent flat again. There is also a small hole in the metal shell from getting a little too close with some welding. The bladder was not affected. $275 These are $628.99 from summit: http://www.summitracing.com/parts/JZP-286-432-06/[/URL]
This cell can be rear mounted on a fj40 allowing you more than double the stock capacity and still have room for a back seat or gear storage. I bought a new cell to replace this one to use the stock pickup and fill plate assemblies.
