c1244 c1207 c1223
Ohio
Vsc light is on. Apparently previous owner replace p/r range switch to remedy code. Didn't work. Any clue on next step?
Getting back to work on this rig, still haven't found solution, did replace all dash light that were out though.
Swapped the yaw sensor with one from my other lc100, problem persists, anyone have a diagram on this circuit so I can check continuity on the wires. Also pulled the abs computer and inspected it, no visible damage. Might try swapping that next.
I don’t have my FSM at the moment, but... where in Ohio are you?
I’m in the Dayton area. Not many cruisers around my area. I know of 5. Two are mine.
