- Thread starter
- #401
Going to try and make this thing a "rolling restoration" - sooner than later.
Welding up the bib.
Welding up the bib.
So tell me again why you arent painting before re-assembly?
Now my local paint guy (PPG) is telling me they can't mix an accurate match and I need to go "out of town" to get proper PPG color. And there seems to even be confusion about the PPG Olive (653).
it may not be pretty but I'll be driving - if I can get through CA smog
Gusb said:Gas tank in and hooked up. Front seats back in along with tail lights, heat shields and muffler. Things seem to be going together, cleaning up a few threads here and there.
New OEM front bumper from Toyota looks really good.
Bib welded up and will just get hit with some EP before it goes back on with fenders.
I had that problem too. I went to the place on Steven's Creek and they mixed up their formula. I brought a kick vent with original paint that had rarely seen the light of day on the inside. It wasn't even close. The owner took it back inside and re-colored by eye (!) and got it very close.
I've got a guy in San Jose that will pre-test it for free if he's not busy and let you know where you stand...
Have you noticed - in bright sunlight, the original paint kind of goes in a "yellow" direction - where all these others (including my PO touchup) go to the "green" side. I don't really see any "green" in my original paint. And PPG calls it Olive Green. Are you thinking of using PC on some body parts?
Gusb said:Much appreciated on the smog - i had planned to try and pick your brain through the process anyway
Got a few things to sort out when it's running, choke cable, maybe a carb rebuild, etc. if I remember correctly there was a slight "stumble" on acceleration when it was last driven. I've got the 1978 Emission Manual from when I did all the stuff before. The local guy who always did smog on my old 80 pickup has always been helpful too.
I'm not sure that I can drink Sierra Nevada and rebuild a carb at the same time, but I 'm willing to give it a shotIf you decide to rebuild your carb, let's get together and do two of them at once. I already bought the carb dip and I have a spare I want to rebuild. If it comes out well, I'll do the one on my '76 too.
Tell me something. Did you springs have different eye size compared to the chassis spring bushing? The pin size looks to be both the same diameter. Just wondering if OME make one spring set for 7/80 down and the 8/80 up and use a different size spring bushing to fit the different years FJ40's.
kiwidog said:Hi Gus,
You sure have been busy. Looking good.
You know you will have to sand all that primer and maybe even shot another coat before you top coat.
Keep up the good work.. I'll want a ride next time we are in HMB.
Thanks jb
... Am I correct in thinking that POR-15 is a similar product to other Epoxy Primers...
Must feel like a million bucks. On the road again - sorta.
Also need to set up a driver's side mirror (no doors for a while) somehow.
