Cube Dweller
Moderator
Getting ready to do my dual cases, rotate the rear axle and redo the brake lines on the 4Runner. Even with the LSPV cranked as far as possible simulating a heavy load it feels like the rear brakes are barely engaging. I need to get this reconciled. I've read elsewhere this is an issue.
Anyone have experience using the Summit valve?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G3905&N=700+115&autoview=sku
My year 4Runner has the brake lines and the power steering lines share some kinda reservoir for ABS, which is long gone on this rig. Next time I yank the engine I'll pull this stuff out and replumb both, but for now I don't want to get into it. So, suggestions on location? Mount it close to a frame rail in an easy location to mount and cut and flare the lines? How about a supplier of brake fittings for the 1/8 NPT to metric dbl flare fittings and metric couplings?
