Hey guys - doing some work on my '78 40, front discs (but i believe they were converted from drums at some point), drums in the rear....question is - with discs in the front - should the valve (#47280) still be there? I was under the impression that was a proportioning valve only for drums?...
I'm swapping in a new master and rear cylinders due to some sponginess and poor overall braking - i first put a rebuild kit in my existing Aisin master - but found the outside diameter of the new pistons/seals were much smaller than stock....so was completely useless - put it back together as was and while bench bleeding found the front circuit wasn't working at all....with or without the valve in place.....also, when installed back on the booster, i found that when i depressed the pedal, that the brake pressure was just venting air out the vacuum hose - is this normal??
