Bracket Holder Support for OEM TOYOTA KYOSAN 2F Transparent Fuel Filter in EITHER Vertical Position ANY Carburetor Equipped Engine
Part # 23921-2FJ60
i designed this mounting bracket / support with 2 main primary factory focus points in mind :
- to ONLY use the best Dam Late Model Carbureted Fuel Filter OEM KYOSAN Genuine TOYOTA Japan Spec High capacity, most surface-area Filter Media ever made specifically for the 8/80-8/87 2F FJ40 / FJ60 UV grade translucent nylon to see any debris inside easily per. the TAN 2F FSM & all owners manuals for the above pro-date's 40 & 60.....fyi
- a very versatile robust & diverse factory focus point's Fit Form & Function minded-set use application philosophy can & does apply to ANY Vintage TOYOTA Vehicle Platform Carbureted Engine that uses a M8 / 8mm ID line / hose from the tank suction side to Mechanical Pump's M8 / 8mm suction side .......
- my high-carbon steel riveted spring-clips to the thick-azz 2mm Violet Blue Silver Zinc-Plated ( highest salt spray rating ) steel plate .
- my universal all Vintage TOYOTA engine bays approach of the trapezoid / triangle shape plate allows the most diverse use of existing OEM captured nuts or studs in either vertical mounting position , with the filter ports remaining correctly horizonal
- the faster holes are M8 ......... yet WILL allow the use of a OEM M6 bolt with a wide fender type body SEMS flat washer , or a OEM flanged hex nut ( qty x 1 of ALL 3 OEM Japan Spec. mounting hardware optional options included as always )
note : Included filter is a TOYOTA OEM Part # 23300-38010 / Bracket Holder assy. is a SEMA-SPEC. Concept Part designed by Rising Sun Mechanical Skunk-Works Laboratory
SNOW VERSION GRADE = HEAVY DUTY TOUGH as NAILS .....
TOYOTA Carbureted Fuel Filter Bracket Holder Designed To Support in EITHER Vertical Position the Late Model FJ40 / FJ60 KYOSAN TOYOTA Genuine Parts Japan Spec. Fuel Filter ( Comes With Qty X 1 OEM Fuel Filter ) Part # 23921-2FJ60 - VintageTEqParts
OEM TOYOTA Carbureted Fuel Filter Bracket Holder Designed To Support in EITHER Vertical Position The Late Model FJ40 / FJ60...
vintageteqparts.com
