RockCrawler.com Bolt On Peace Of Mind For Your Spidertrax Spider9 With Samco Fabrication?s New Skidpl
Samco Fabrication has developed a new bolt-on skidplate for Spidertrax Spider9 axle housings to add strength and protection to your expensive third member.* The removable third member used in Ford 9” axles makes for easy gear ratio and differential swaps when compared to traditional axle housings, but only if the mounting studs on the housing [...]
Samco Fabrication has developed a new bolt-on skidplate for Spidertrax Spider9 axle housings to add strength and protection to your expensive third member.* The removable third member used in Ford 9” axles makes for easy gear ratio and differential swaps when compared to traditional axle housings, but only if the mounting studs on the housing are not damaged and bent.* Racing and hard recreational use can lead to impacts that damage the studs or even crack the third member, resulting in catastrophic failure.
The Samco Fabrication skidplate is the only product of its kind designed specifically to compliment the increased ground clearance offered by Spidertrax Spider9 fabricated axle housings.* The precision crafted skidplates are fabricated from 3/16-inch zinc-coated steel and mount to three existing bolts on the front pinion support and two supplied tabs that are welded to the back of the housing to act as a girdle and add strength to the entire axle assembly.
While it does not fit high pinion third members, Samco’s Spider9 skidplate does fit traditional third members and is considered essential for anyone running a Spider9 in desert race or rockcrawling environments.* The Samco Spider9 skidplate is being offered for an introductory price of $84.99, and is the perfect complement to the Samco Ford 9” seal retainer.
For more information about Samco Fabrication’s new Spider9 skidplate and the rest of their desert racing-oriented products call*775-856-4100 or visit them on the web atwww.samcofabrication.com.
Contact:
Samco Fabrication
862 Watson Way
Sparks, NV 89431
(775) 856-4100
Link
