G'day All,
Did a search and couldnt find anyone with an issue like mine, most seem to be a faulty booster or vac leaks.
My vac booster never worked, press it in, cover the port and let it out and no suction. Put in a new booster, no difference at all. Pulled the vac lines to the booster and there is no vacuum.
Brakes have vacuum at the booster. Pulled both the lines off at the pump, which leaves me with two barbs, the brake vac line pulls enough vacuum to suck my finger into the tube, the clutch booster vac line has NOTHING. They look like they both come from the same block on the pump, so what gives? Could there me a blockage or is there something inside the block? The manuals I have were not very helpful.
When everything was stock with VAC transfer case everything work (except had a heavy clutch) 4x4 worked, brakes have vac, engine swtich off fine.
Any ideas?
Any ideas?
