Hi
I have started having brake problems lately and I am not sure of the exact cause of it. Here’s the problem:
When I give a medium to a hard push to the brake pedal, the pedal get very stiff and the truck don’t brake much. However, after a second or two, the brake pedal pressure get’s to normal and the truck brake normally. On the other end, if I apply a very gentle pressure on the pedal when braking, I don’t have the above symptom.
I’ve read a few posts but couldn’t find this exact problem. So far, I’ve check the brake lines and they don’t leak. Moreover, the vacuum from the alternator to the brake powerbooster is also OK.
I suspect that the problem is more related to the brake booster diaphragm. Am I on the right track?
Do you see something else as the cause of the problem ?
Thanks!
Denis
Thanks!
Denis
