Will the power steering components from a BJ fit in a HJ/HZJ?
The box is the same, the pump is totally different.
HZ pumps are gear driven, B & H pumps are belt driven.
~John
can you elaborate on what you are building?
you can mount any pump on a HJ(2H engine) but not the HZJ.
the box on the BJ60 is the same as HJ60 but not the same in the HZJ75,opposite rotation and rearward pointing pitman arm,it all depends on what you want to do.
Simon
if you have the 1HZ engine,the power steering pump is mounted on the leftfront side of the engine,are you missing the ps pump and the vacuum pump.?
Bj70 box is the same as HZJ75,and the lines you can make or buy .
l am wrecking a BJ70,when l am done the engine swap into a FJ45,l may have some parts for sale.
also wrecking a HJ60.
also one of my customer is selling a 86 HJ60 with a low mileage rebuilt 2H(he spent $10,000 canadian about 6 years ago),h55 with marks gear,4.88,35",arbs front and rear,AXT turbo with 3" exhaust,and a lot more,he only drive his BJ40 now and is into triumph and mg sport cars now.
Simon
