Hi,
I have just attempted to adjust my valves for the 3rd time on my '83 FJ60 2F. I noticed that after setting them i could still hear some ticking noise when running the engine with the valve cover off. I put a long screwdriver on the top of each one to see if i could hear a difference on some and i could. One valve in particular (No. 3) was quite noisy despite being adjusted on the tight side of being correct. I then noticed something that didn't look right. On the side of the valve where the nut is loosened and adjustment is made with a screwdriver, directly underneath the nut assembly there is a cylindrical metal stem that goes down into the head (is this the valve stem?). These seems to spin around on all of them as the valves go up and down. The stem on the valve in question was "wobbling", i.e. it looks bent. They all seem to have a slight movement from side to side if wiggled with the engine is off. But this particular one definitely is bent as demonstrated by spinning it around. The No.1 valve also does this but to a lesser extent. Wondering if this could be causing a) valve noise and b) small amounts of smoke from exhaust after idling for a while and using oil in general. Is this likely?? Is is difficult to change these or does the head have to come off to do it??
Thanks
Mark
Thanks
Mark
