Beeping from fuse box???
SLC, UT
2003 Tacoma 3.4 V6 230,000 miles
Everything runs fine.
There is a beeping sound (loud and high pitched) seemingly coming from the fuse box. There are only 3 ways to make it stop.
1- disconnect the battery
2- turn on the headlights (first position minimum)
3- pull the taillight relay
Any help would be appreciated. I have no idea what might be the solution, but I hope it’s fairly simple.
Thanks.
Noise located: problem solved even though the cause is unknown.
The truck did not have keyless entry, but it had the speaker/beeper installed.
I don’t know what caused the speaker to malfunction, but unplugging it has solved the sound problem and the truck still runs great.
