I’m in the process of relocating my battery to the bed of my truck. While I’m at it, I want to plumb in a kill switch. After lots of reading, Im opting to put it on the positive cable prior to powering any accessories (willing to be persuaded differently). The purpose of the switch is to kill power in an emergency situation (e.g. rollover, stuck winch, etc) and not for general storage to avoid drains.
I bought two switches with the following load ratings:
Blue Sea 3000:
Continuous 600A
Intermittent 900A (up to 5 min)
Cranking 1750A
RingBrothers 99000-6105:
Continuous 275A
Intermittent 455A (up to 5 min)
Cranking 1275A
My biggest concern is capacity of the switch while winching. I’m running a Smittybuilt 9500 and the max amp draw looks to be about 440A with average draw around 200A.
I’m running 1/0 welding wire from the battery to the switch and then to a positive stud in the engine bay which will power the winch.
I guess it seems somewhat obvious to go with the BlueSea but the other switch has a better enclosed design as I’m also worried about shorting this junction as it will be in the cab. It’s also smaller and easier to package. While it doesn’t seem like I winch for 5 min straight, I guess it is probable that it would happen at some point.
Which would you go with?
Blue Sea 3000:
Continuous 600A
Cranking 1750A
Continuous 275A
Cranking 1275A
