Barnes 4WD Toyota Differential Cover
Barnes 4WD is proud to introduce the first Toyota Diff Cover that offers complete protection for your third member, maximizes clearance and increases fluid capacity. This cover is not your typical cap that you just weld over the thin stock housing. With our cover you completely remove the factory cap (a quick job with a cut off wheel) and weld a laser cut and bent ¼" A50 Plate Steel cover in its place. This is a little more work but the payoff is worth it for the total coverage and increased oil capacity. This cover will fit front and rear Mini Truck and 4 Runner axles, IFS rear axles and even Toyota Tacoma axles with a TRD E-Locker. Covers ship fully welded with a large fill plug so all you have to do is prep your axle and weld it on!
