RockCrawler.com Bailey’s Snatch Block
The Bailey’s Snatch Block is designed for off road enthusiasts who*want a commercial grade snatch block that is affordable and made in*the USA. The 4” steel sheave is machined to a smooth finish for use*with synthetic winch lines and cable up to 7/16”. A self-lubricating*bronze bushing is pressed into the sheave for maintenance free use.*The [...]
The Bailey’s Snatch Block is designed for off road enthusiasts who*want a commercial grade snatch block that is affordable and made in*the USA. The 4” steel sheave is machined to a smooth finish for use*with synthetic winch lines and cable up to 7/16”. A self-lubricating*bronze bushing is pressed into the sheave for maintenance free use.*The design of the laser cut side plates allows you to rig the block in*seconds and utilize the large opening for a variety of rigging*options. All steel parts have corrosion resistant zinc plating.
  • *Working Load Limit 4.5 Tons, 9,000 lb. (4:1 Design Factor)
  • *Ultimate Breaking Strength: 41,000 lbs. (tested w/ 1” shackle)
  • *Wire/Synthetic Rope Size up to 7/16”
  • *Length: 10 ¼”
  • *Weight: 7.35 lbs.
Bailey’s Towing Accessories Inc.
1422 Wall Road, Wake Forest, NC 27587
1-919-562-2984
www.baileystowinginc.com
“We do it right!”
Link
