ARCHIVE ARB Compressors On Sale With Free Shipping
FUELED 4WD
WWW.FUELED4WD.COM
Las Vegas
Website
www.fueled4wd.com
Tires perform best when they're set at a pressure that's appropriate for the terrain. While highway use calls for a relatively high pressure rate, lowering your air pressure will dramatically improve your 4x4's traction in a range of off road environments. Compressed air allows you the freedom to adjust the tire inflation level of your truck to suit the conditions.
Few 4x4 accessories offer as many advantages to 4WDers as readily available on-board air. Considered by truck owners around the world to be a staple accessory for off road travel, an ARB 4x4 air compressor provides an immediate source of compressed air anywhere a 12 volt power source is available.
An equally beneficial feature of on-board air is the ability to re-inflate tires that have been repaired - it's not unusual to get several punctures in one day when 4WDing in extreme off road conditions. In this environment, the value of owning a 4x4 air compressor is priceless. When coupled with good quality tire repair equipment, an ARB air compressor provides the off road traveler with independence and peace of mind.
ARB 4x4 air compressors are individually leak tested, current draw tested and flow tested under load at the factory before packaging and come with a comprehensive 2 year warranty. And ARB's after-sales service is second to none with many of the compressor components readily available and easily sourced.
Questions email us at sales@fueled4wd.com or call 888-825-6284
For More information Click Here
