Any plumbers here?
No plumber though I've been playing one the past couple days. :mad: Had to repair a water fountain that was knocked off the wall. New drain pipe, new copper inlet, and had to solder the copper tubing in the coil running around the tank. :eek: Then had to replace an element in a water heater and the next day had to replace the pressure/temperature relief valve because it was faulty. At least I got to play with a torch. :D
I just paid a small fortune to have a pipe snaked. I had no idea they put the snake in through the tube sticking out of your roof. You learn something new every day.:D
That would be the vent stack that lets the sewer gass out and prevents a vacume when your toilets flush and sinks drain. I have to do the same thing as the damn squirls have cloged them up. Works to stick a garden hose down there as well.... But we all knew that.
Licensed Plumbing Contractor here... what's your question.
