So im putting an auxilliary tank into my fj45 troopie - i have already made the main body of the tank [same style as the 'long ranger'] which will fit above and beside the rear drive shaft - but im wondering what kind of ports i should make room for on the top of it - so far i have the sender installed - the filler neck in [i split the filler neck to allow filling of both tanks through the one nozzle] and a breather tube leading into the factory tank to allow for fuel expansion. i also have led one fuel line from the bottom of the tank to an in-line switch valve to manually switch from one tank to the other - via the underside of the car...
it is made of MS steel - base coated and painted...
is there anything i am forgetting?
