Any 60 Series Gurus near Athens
Athens, GA
Are there any 60 series gurus near Athens? My 60 decided a couple weeks ago that it will only start or idle or run when it wants. I found a broken fusible link, which would answer some of the other issue it had at the same time. I replaced it with the one from CruiserTrash, but it still won't start, just cranks. If anyone is local and could give me a hand after the Relic Run this weekend, that would be fantastic.
Fuel
Spark-timing.
Did you change the carb?
Are the plugs wet with gas?
Did you adjust timing?
Does it turn over? If not are all wires connected to starter? I re read it and see it cranks.
Manual or auto choke?
Are you getting spark to plugs?
Is your battery ground good?-prob if its cranking.
Have you checked all ign fuses or relays?
is fuel pump verified working?
will it try to run with carb cleaner sprayed in carb?
is your coil/igniter hooked up, properly?
new/rebuilt or worn out engine? Compression numbers?
Did you change the dist?
Coil to dist wire new/good?
Rotor/cap good?
Added info after I reread your post.
