Been doing my homework on this. what are your preferred mounting ways?
Diff end - welded bracket to housing - pro's - stout as the welding work - cons - might warp the housing from the heat, as strong as the welding work (if the welder can't weld... i.e. me).
bracket that bolts to the Diff studs - pro's - removable, won't tear a chunk out of the housing if it all goes wrong. con's - thats alot of load to put on those studs IMO
xmember end. does anyone use the standard tube X member? or am i better making another xmember up? i was considering incorporating the mount into the bash plate i was going to make
