I have installed the same suspension as Bandi. I have mounted the same tires as you have on stock rims. The system is great. The ride is better than stock and I love it. I do have a couple of concerns. The first is that I did not lift the front as much as I should have because I was getting negative camber. The more lift the more the negative camber. The second reason for not lifting the front completely was that I did not know how much lift I needed to allow for the ARB front bumper and winch that I plan to install later this month. The second problem is I worry about the tires rubbing. People say they won't but they are close. Any definitive answer?
If anyone has any ideas about the camber and the lift necessary for bumper and winch, I would love to hear them. What is the easiest way to adjust the front shocks? I don't like the idea of using a hydraulic ram: something about putting my hand into an area that might bite me. One thing I did find out was to do all your measurements from the frame. My body is not level, however, the frame is.
What part of Van do you live in? I live in Queenborough
