Has anyone used a grid heater like on the Cummins on a Toyota diesel?
Ya my 13B-T has one. Glo plugs suck. My opinion .12H-Ts and 13B-Ts have them.
I agree. Glow plugs suck. Did you use the Cummins intake block spacer and do you manually operate? Thanks![]()
I find it odd that Toyota used glowplugs on the 1HDT. Other direct injected engines seem to have screens. I really don't know which work better but I do think Direct injected engines start better even when you don't use any glow system. My 3Bs would never start at 0C without glowplugs but the 13BT does it regularly (I have manual control on my BJ74).
One trick for glowplug rigs is not to fuel them too much when cranking. The fuel spray cools the glowplug.
Glowscreen = crank with foot on floor
Glowplugs = crank with slight pedal
Don't hook it up directly to your existing glow plug controller circuit. Intake heaters typically consume a lot more current than glow plugs.
I must be missing something: I always understood on direct injected diesels there was no need to ever touch the skinny on start-up. I know that the TOYOTA manual says slight pedal for the B series.
BUT then havnt been in anything colder than -14 with the 74, I didnt even wait for the grid it fired on second rev.
even on the coldest days -30C my 3B will start with 8 seconds of holding the glow plugs...
that's what I'm thinking! I know they burn out once and a while and there is some related circuitry, but they work! They're easily tested, replaced and I don't think there's a better way to start an IDI diesel![]()
