I've done a bit of searching and haven't come up with anything so I figured I'd post up.
The factory stereo in my '97 was in need of replacement. I picked up a Pioneer DEH-6200BT (Pioneer DEH-P6200BT CD receiver at Crutchfield Signature) and what I thought was the right connector from BB. Got home and put it all together but I didn't have any sound. So I did some searching and found some info stating that I need to bypass the factory amp with the spare molex connectors behind the head unit. Of course that wasn't the cable I had and I didn't feel like trying to determine and then cut, my wires up.
So, I ran to Wally World and grabbed the other connector and I started to piece it together but I won't get to test it until tomorrow morning. My question is this, if I use the amped molex connection and my preouts, how do I get power to the amp or at least the signal to tell it to turn on? My guess at this point is that everything was decent except the amp was being sent an on signal.
The first harness I picked up is the following:
Toyota/Lexus Wiring Harness For select 1992-99 models with factory amplifier at Crutchfield.com
I'm assuming I could hook the remote wire up to a wire telling the amp to turn on however I'm not sure which wire that would be on the factory harness. Any thoughts? If I go with the second harness and the grey molex connectors, I believe I have read that I need to unhook my amp. If I go this route, which connection should I unplug from the amp as there are two?
Thanks for the help.
Tripper
Tripper
