Greetings, fellow GX enthusiasts. I recently had the bad fortune of discovering a seized AC compressor on my 2009 GX. The pulley works fine when the clutch is not engaged, but with it engaged, the compressor will not move and the serpentine belt releases the howl of a screaming banshee (how I discovered the issue).
So, I am looking at replacing the compressor with a new Denso unit. My question is, what other parts require replacement as well? I am looking at this kit from Napa which includes a compressor, front expansion valve, and a receiver dryer.
I've read that a seized compressor can introduce metal into the system and was wondering if I needed to replace any of the rear ac components as well. While we do not currently use the rear ac, I would hate to have a problem down the road because I didn't address something while the system was already apart. I am considering buying a rear expansion valve as well, but thought I would get some advice from those who may know better than myself. With that in mind, any input would be much appreciated!
