Has anyone here done this and know whats involved with it? My case is machined flat where the two sensors go. Im assuming the holes will need to be drilled and tapped but does the shift fork inside the tcase have the little grooves on it to index the switches? Anything else involved?
Im trying to use the Neutral switch to run my AT P light on the fj62 shifter im putting in my fj60 and the Low range switch to send ground to my 5.3 PCM to tell it to enter the 4low tune and trans shift table.
Thanks
Thanks
