ABS Warning Light
Hi,
I'm new here and this is my problem. Well, it started out like a year ago when the ABS light suddenly came on with a warning sound. It was raining at that time and it went away the next day. Now it's back and it won't go away. But it would only come on and off. Like it'd come on for a while and it'll go off again.
I'd like to know how to check for ABS codes and what those codes are without a code reader. I live in a country without a toyota service station. So I need to do it myself. Thanks
kksh
Abs lamp on with an audible noise is usually an internal seal failure inside the mastercylinder booster assy , Moast Abs codes are manufactuer set and wont show details on an non toyota Obd/2 tester ,and are not able to be retreived manually that would provide the data nessary for a full repair
solution
Hi,
Let's say it's the master cylinder seal failure. Are there any ways to fix it without having to replace the whole thing? And if I have to replace the whole thing, what parts do I have to replace and how much does it cost to buy that part over there in the States? Thanks for all your help guys.
KKSH
