ABS system w/ rear semi-floater?
ABS would pull an error code and function would be compromised / dissabled.
Yes, the FZJ80 equppied w/ABS is a four wheel system - sensor at each wheel.
With the addition of a SF, you will run w/ABS light on & non-functioning ABS / standard braking - not good for a 6K+ vehicle / rearend will fishtail all over the place in an emergency stop
Just my inflated 0.02 cents
Thinking about an axle swap from a super-high mileage FJZ80 and then resell. But that's compromising more than braking then, and would cause problems on sale anyway...
Although theoretically, I can't imagine that no-ABS is that bad even at 6k lbs?
Just thinking...
I dout you will notice the ABS. The only time it really makes much difference is in wet weather or loose driving surface.
