Well I went and bought 2 new OEM Courtesy Switches
P/N 84231-12080
Just took 15 minutes roughly to do the 2 front doors.
Needed a small pocket sized flat screwdriver for depressing the connection clips, a 1/4 inch drive ratchet and a 10 mm 6 point socket.
- with hands pry the trim out on the pillar between the front and back door on the inside, approx 3 clips need to release starting from the top down. This allows enough room to get at the connection clip.
- depress clip retainer with small screwdriver and pull out connector
- pry up rubber cover on switch to find the 10 mm fastener and remove it. Pull out switch assembly and about 4 inches of wire follows quite easily.
- put new switch back in curling wire back into opening to plug back into connector
- install 10 mm fastener again and tighten, push rubber dust cover back over unit.
- plug wire connector back into socket until you hear the click that it is in all the way
- push plastic trim back in from the bottom up making sure all 3 clips go back in properly.
Done and works like a charm
