- Location
- United States
94 80 For sale locked and loaded
Long time no post.
Putting my 80 up on the block. Located in Denver.
Not perfect, but turn-key. 10,500 Needs no mods to go anywhere within reason. If you came to moab last 2 years, you saw me on all but pritchett and the like.
Cruiser Modification/Detail listing:
maintenance items within the last year
• New cap/rotor/wires
• New pads (ceramic) front/rear
• New rotors (front/rear)
• Wheel bearings just done w/new seals
• New radius arm bushings
• New rear link bushings
Modifications:
• Slee adjusters
• Slee 4” coils (2nd gen I believe) ome "L" shocks
• Custom caster correction radius arms
• Custom re-inforced lenth corrected rear lower links
• Slee t-case skid
• Custom sliders with catalytic skid and steps
• Custom rear bumper (way less overhang than slee, arb, etc) integrated hidden receiver (doesn’t stick out past bumper – rcvr inside frame space) Tire carrier will accept 40” tire if inclined)
• Highlift mount on rear carrier
• Custom low profile front bumper (guaranteed only better approach is no bumper) with 8k winch, light and antenna mounts. Built in rcvr/dryer protection. Standard warn bolt pattern. Integrated stainless fairlead.
• Aluminum roof rack made from recycled materials – like a moose rack
• Blacked out wheels
• 315 mt/r’s
• Stainless brake lines
• E-brake thoroughly adjusted and works
• Rear brake height adjuster set correctly
• Dual batteries – red-top main rear yellow top (winch and rear power)
• Rear 12v outlets
• Custom rear deck with storage
• Sony mp3/wma/cd/aux input deck, nakamichi speakers, jbl 50w nominal amp and 12” jbl sub under storage deck
• Cdl switch/mod
• “nakman” cb mike holder in console (2)
• REAL cb mounted on back of console with REAL antenna (both tuneable)
• Relocated and re-wired fm/am antenna wire it will NEVER come off/bend
• 4” flat beam auxiliary lights wired into low beam
• Hand throttle
• Front aux 12v outlets
• K&n airfilter
• Dog guard (not factory)
john at forgingsdesigndotcom for details if you need more.
Long time no post.
Modifications:
• Slee adjusters
• Slee t-case skid
• 315 mt/r’s
• Rear 12v outlets
• Cdl switch/mod
• Hand throttle
• K&n airfilter
